Hi everyone. I just got my first 08M starter kit and have a couple questions as I read over the manual.
1. Even though the Picaxe initializes itself to a certain pre-determined start-up state, do you generally start your program with an initialization routine? In other words, do you define certain pins as inputs or outputs, (just to be sure), even though thats the default power-up state? I suppose another way to say this is . . . is the default power-up state reliable?
2. Can you use the "dirs =" command to assign I/O to pins that are already hardware set? For example, is there any problem with issueing the command: "let dirs = %00001111" even though pin 3 is hard-wired to be an output?
3. I know that in basic, the "LET" command is archaic and never used. Is this also true in Picaxe programming? Can I omit it in all cases?
Thanks all. Looking forward to playing with this thing.
