Rampz
Well-known member
Following on from my question ref can a certain pib be used for ADC input, the question was leading to this.
I have bought a SCA60C module online its based on a chip by VTI N1000060, it has a LM393 to give 2x switched output that i was hoping to use in the first instance, but it seems they are really too sensitive for what i want, there is also an analogue output that goes from 0 degrees through to 180 degrees, the output starts at 0.5v and goes through to 4.5v.
I found some code from a post on here that displays voltage from the readadc10 command
Using the above code and trying to merge with other code that takes say 50 readings then averages it out, my ouput reading is way out, i guess due to my lack of grasping ADC maths
It does give me a voltage display and it does change when the board is tilted either way, but my output is going from 0.4v to 4.5v and i assume the code above is going from 0v to supply? I have been reading up on adc maths and really not getting my head around it all.
In my code i am running the clock at M16 because the code it will ultimately be used in is running at that speed.
I'm using this module because it seems slightly easier in my head to deal with an analogue voltage rather than something digital, but that said the module i bought is obsolete and has been for several years, so maybe i should be starting somewhere else.
This will ultimately replace the tilt switch input that i currently use, the tilt switches are Mercury based, they don't work all that great and are the weak link in everything, if there is a 1, 2, or 3 axis sensor that i should really be using instead of try to get really old technology to work i'm open to any ideas?
Ok so with some playing about and loads of reading, gone right back to the start, i have no need to display what voltage is coming from the module, so instead will display the ADC10 value, then if thats 1023 divide it by 180 degree's to give 5.68 ADC points per degree.
with the pcb laid flat it should give about 90 degree's which it does and it alters nicely in both directions, but having measured the output of the module it seems to go from 1.186v to 3.384v i guess thats something to do with either the multimeter or the LM393 thats on the pcb too?
Either way how do alter my scale to get rid of the lowest part of the range and the top part, since due to the chip i can't reach either?
#picaxe 08m2
SetFreq M16
#no_data
#terminal 19200
readadc10 c.2,w0
w0 = w0 * 44 / 9
bintoascii w0,b2,b2,b3,b4,b5
sertxd (b2,".",b3,b4,b5," Volts ",lf)
goto main:
#picaxe 08m2
SetFreq M16
#no_data
#terminal 19200
readadc10 c.2,w0
w0 = w0 * 21
w0 = w0 / 119
sertxd (b3,b4,b5," degree's ",lf)
pause 3000
goto main:
