I got the 8x8 LED matrix soldered together a while ago but I did not properly plan the control board for it so I've had to breadbord it as much as possible. I have written a program where a single LED lights up, and goes in a circle around the edge of the 8x8. This animation alone takes up 2028 bytes of 2048. Is there a way to condense the program?
The pulse is sent to a 4017 decade counter, the first pulse is for the reset the other for the clock pin. I am doing each "frame" of the matrix like this:
This frame is just the upper left LED lighting up. And I repeat that 29 times in total if I've got it right. Is there anyway to make things take less space? If I was going to send a binary number I could do it like this:
But with the matrix it's not like a sequence of binary numbers, it's different patterns that need to be mapped individually for each row in every frame. What to do?
let dirsB =%11111111
let dirsC =%11111111
let pinsB =%11111111
let pinsC =%00000000
let b0 = 0
'frame 1
for b1 = 0 to 5
pulsout C.0,10
let pinsB =%10000000
pause b0
let pinsB =%00000000
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
pulsout C.1,10
pause b0
next b1
for b0 = 0 to 15
let pinsB =%b0
next b0
