I am trying to use the 8M2 to drive an LCD board, and run into problems, even though I am using code that apparently was OK in 2013.I have looked for samples in the Forum using the 8M2, and found several ones. However, it seems that something has changed, for while the old code apparently ran at the time of the publication, the same code gets now rejected because of syntax errors.
Is there something changed with the syntax for the 8M2 between now and 2013? dirsB = %11111111 was a correct statement then, while it gets rejected now. Same with pinsB = b1.
(They both are now syntax errors)
Can anybody tell me how the output pins of the 8M2 are used now?
My goal is for a 8 bit Port to output one hex character at the same time, not one Port output line at the time.
Any comments are appreciated.
