I try to compare signals from 2 LDRs for solar panel tracking. I use PICAXE 8M, ADC1 and ADC2 and have thye LDR with 680 Ohm resistors as voltage dividers. When monitoring the input signals on Debug the following problems occur:
1. the signals are relatively unstable, eg. between 98 and 117 digits with constant light level.
2. Although exposed to the same light level both vary in opposite direction: eg 98/117, then 115/100 etc.
3. As soon as I shade one LDR, the second value changes too, eg. shading sensor 1 reduces its signal to 29, but sensor 2, still exposed to full light comes back to 70.
I have replaced the LDR with highly constant, variable power supplies and the croos-interference remains. Does anybody have an idea?
Â
Â
