Trying to work out the best way to communicate between 8 buttons (ideally would like to know the state of all buttons, don't need to sample any faster than 5hz) over a single wire (with common GND and power supply) back to a PICAXE
Possibles:
All help appreciated!
Possibles:
- R-2R 8 bit resistor network - risks problems as the 1 wire is several meters in a noisy environment? even with 10bit adc, wonder if I could misread buttons
- another PICAXE 18m2 transmitting back with serial. Is there an easy way to code 8 inputs into a serial string, and decode that into a Case statement with actions for each button being active?
- is there a made for the job IC or something else?
