As the title says, I'm only getting the first chip (address 0) to work in a string of 6 24xx512 eeproms (3 are 24AA512 and 3 are 24LC512). I've used up to two before without any problems, but now that I've got all 6 together I can only access address 0 (10100000). I can write and read fine from it, and none of the others. They all just return 255 on a read. I've tried writing and reading at 100 and 400khz (well, I guess...I'm using i2cfast16 and i2cslow16).
The code I'm using is along these lines:
i2cslave %10100000, i2cslow16, i2cword
b0=%11111111
b1=%00000001
writei2c 0,(b0,b1)
b0=0
b1=0
pause 10000
readi2c 0,(b0,b1)
sertxd (#b0, " ", #b1,cr,lf)
I'm then just manually changing the address and reloading the program (I'm just testing the memory on the board I just finished).
It's all addressed right hardware wise and the connections are all correct with respect to wp (tied to 0), vdd, vss, and sda/scl.
I cant figure out what's going on. The other chips all have worked fine as recently as yesterday (I tested them all a couple at a time to make sure they worked before I put them on the board) and I dont see how I could have fried them, so where am I going wrong?
Any help would be greatly appreciated.
--Andy P
Edited by - andypro on 8/31/2005 5:28:47 AM
b0=%11111111
b1=%00000001
writei2c 0,(b0,b1)
b0=0
b1=0
pause 10000
readi2c 0,(b0,b1)
--Andy P
