Thanks Tom2000. Something like this
http://martybugs.net/wireless/collinear.cgi perhaps? Or
http://www.rason.org/Projects/collant/collant.htm
Is it mounted vertically, ie with the antenna 90 degrees to your drawing? I gather a collinear gets its gain (when mounted vertically) by sending less energy up into the atmosphere or down into the ground. Yagis are great, but for a wireless mesh, it is better to have an omni, and a collinear might be just the right answer - some gain but in an omni direction. I'll see if I can put one together.
The links didn't use a dipole. Is the other half of the dipole needed?
Thanks for the links! I really like the coax collinear design. I've never seen one of those. It appears to be relatively simple to construct, and provides a whopping amount of gain.
Any "gain" antenna gets its gain by concentrating the radiation in one or more preferred directions. For a vertically-mounted collinear mounted in ground proximity, the radiation pattern will be sort of a truncated toroid. Think the top half of a sliced bagel. The more antenna gain, the flatter the bagel. For a simple dipole or 1/4 wave vertical, a very fat bagel.
Yes, you can certainly cut "my" antenna in half and mount it vertically. At the antenna feedpoint, connect the coax braid to four equally-spaced 1/4 wave radials, or perhaps a square yard or two of hardware cloth, chicken wire, or whatever you might scrounge. However, once you're fooling around with radials or a ground plane, mounting arrangements, perhaps a decoupling sleeve, etc, you're probably better off building that 9 dB coax collinear. Mechanically, it's a simpler task.
At least, with some sort of ground plane arrangement, you won't need a balun.
By the way... I see that the 2.4 GHz collinear uses coiled matching stubs. On one of the versions of "my" antenna I built for 144 MHz, I tried coiled coax matching stubs. Didn't work at all. I think they acted like chokes, not like stubs.
I'd recommend that you build the stubs out of stiff copper wire, configured as shown on my sketch -- out, squared off, and back. At 315 or 433 MHz, maybe 15 or 20 mm spacing.
By the way... I built these as dipoles to neatly solve the problem of preventing the coax shield from radiating. When you eliminate "the other half" of the antenna, shield radiation becomes problematic, and can destroy the efficiency of the antenna. Note the measures that the designer of the coax collinear has taken: a 1/2 wave decoupling sleeve
and the toroid cores which act as an RF choke for unbalanced RF energy on the shield.
The "half dipole" configuration over either radials or a ground plane is a compromise, but one that should be reasonable for this application. The better solution would be radials or a ground plane and a decoupling sleeve. But that's approaching the ridiculous. Mechanically, it's much simpler to construct the antenna as a dipole, avoiding the shield radiation problem completely.
Have fun!
Tom
