Sorry cant upload image as them forum wouldn't let me for the keyboard! But the schematic digram for the connection can be anything it doesn't matter!In case it is not in a "standard" matrix format can I suggest that you post a link to the keypad datasheet or provide a schematic diagram for it.
Then post a schematic diagram showing how you have it connected to the PICAXE.
Thanks I will look into that!hi red-eye,
Think you should have done a forum search, but to get you started look at hippy method http://www.picaxeforum.co.uk/showthread.php?14001-20X2-4x4-keypad-scanner&highlight=keypad+20x2 their are a few ways of scanning a keypad but hippy's method is by far one of the best I've seen. Hopefully it will work on a M2.
With respect it does a keypad is made up of rows and columns you got too work that out or use the data sheet,.But the schematic digram for the connection can be anything it doesn't matter!
Could you explain further please?Sorry cant upload image as them forum wouldn't let me for the keyboard! But the schematic digram for the connection can be anything it doesn't matter!
Further to that, if the item is illustrated or for sale on line, you could post a link to the item.Could you explain further please?
The Forum accepts a wide variety of formats.
e
,Could you explain further please?
e
8 pins, one for each column and one for each row. 4 columns, 4 rows. haven't wired to picaxe help needed on thatFurther to that, if the item is illustrated or for sale on line, you could post a link to the item.
I have used 16-key keypads that use a 1x16 (17 pins), 2x8 (10 pins) and 4x4 (8 pins) matrix. How have you wired it to your PICAXE?
If you want help, you need to be specific.
p
The image is a jpg but i'm on a MAC might have an affectSo what format is the image in.
@ REDEYE,8 pins, one for each column and one for each row. 4 columns, 4 rows. haven't wired to picaxe help needed on that
So what exactly have you done so far ??I have tried many different ideas but none so far successfully.
Outputs of what?however the outputs need to be binary code to go down a DATA bus.
Valid file extensions: bas bmp cad doc dsn gif jpe jpeg jpg pdf plf png psd txt zip
Have a look at the wiring diagram from the link I gave back at post 2.http://emartee.com/product/42022/Mini 4x4 Matrix Keypad
Is a link to the a very similar keypad but mine is slightly older and i don't know where it is from but is the same style as this one
