4x20 LCD Big Numbers - Part 2
shakespeare
The image below shows the character set defined in Part 1's code. It is possible by manipulating the definitions a bit more to achieve some alpha characters as well, although some will be hard to distinguish, such as I and 1. W and M look a bit scruffy in this size.
Where this unit could be handy is as a display of 5 analog inputs - 4 "minor" values on one side in normal font and one "major" one in "Bignum" font
Here is the basic circuit diagram of my current setup. R4 is there because I was originally using an 18A, which requires a resistor to hold the reset pin high. The 18A can run the code in Part 1, but you don't have a lot of program space for making good use of the unit when you use the big font.
Finally, here is code for the same unit to run a count from 0000 to 9999 repeatedly:
symbol e=5symbol rs=4
symbol bbit=3
symbol lbit=2
symbol twoline=8
symbol scroncron=14
symbol clr=3
symbol redled=7
symbol redpb=pin0
symbol whtpb=pin7
symbol yelpb=pin2
symbol tbout=6
symbol serpin=6
symbol char=b2
symbol index=b3
symbol Line1=0
symbol Line2=64
symbol Line3=20
symbol Line4=84
symbol SetDDRam=128
symbol ShiftLeft=24
symbol ShiftRight=30
symbol bnum=b4
symbol defidx=b5
symbol numadr=b6
symbol bchr=b7
symbol tnumadr=b8
symbol cpos=b9
symbol coff=b10
symbol idx2=b11
symbol total=b12
symbol wtotal=b13
symbol windex=w8
symbol wstore=w9
'Initialise IO
    dirsb=%11111111
    dirsc=%00001000
'Initialise display unit
init:
    let pins = 0           'Clear all output lines
    pause 200             'Wait 200 ms for LCD to reset.
    let pins = bbit        'Set to 8-bit operation
    pulsout e,1
    pause 10              'Wait 10 ms
    pulsout e,1            'Send data again
    pulsout e,1
    let pins = lbit        'Set to 4-bit operation.
    pulsout e,1
    pulsout e,1            'Send data again.
    let pins = twoline      'Set to two line operation
    pulsout e,1
    let char = scroncron    'Screen on, cursor on instruction
    gosub wrins
    char=clr
    gosub wrins
start:    'set cursor flag to line 1 col 1
    cpos=146
    setfreq m32
    'Define CG0 to 7:
    eeprom (31,31,0,0,0,0,0,0)
    eeprom (0,0,0,0,0,0,31,31)
    eeprom (24,24,24,24,24,24,24,24)
    eeprom (3,3,3,3,3,3,3,3)
    eeprom (3,7,14,28,24,24,24,24)
    eeprom (24,28,14,7,3,3,3,3)
    eeprom (24,24,24,24,28,14,7,3)
    eeprom (3,3,3,3,7,14,28,24)
    char=64
    gosub wrins
    for index=0 to 63
        read index,char
        gosub wrchr
    next
    'Go back to DDRam
    char=cpos
    gosub wrins
    'Define bignum data 0 to 9
    eeprom (86,52,52,120)    '0
    eeprom (3,3,3,3)        '1
    eeprom (86,8,80,114)     '2
    eeprom (86,8,6,120)      '3
    eeprom (52,120,4,4)      '4
    eeprom (81,112,6,120)    '5
    eeprom (86,48,86,120)    '6
    eeprom (22,4,4,4)        '7
    eeprom (86,120,86,120)    '8
    eeprom (86,120,4,120)    '9
    'display title
    char=128
    gosub wrins
    eeprom 200,("BIG COUNT   ")
    for index=200 to 211
        read index, char
        gosub wrchr
    next
    'Display a count from 000 to 9999
    for windex=0 to 9999
        wstore=windex
        for idx2=1 to 4
            wtotal=wstore % 10    'Mod to get least significant digit
            wstore=wstore/10      'Div to shift digits down 1 decimal place
            bnum=wtotal
            gosub wrbig
        next
        pause 8000               'Pause 1 second to get approx 1Hz count at m32
        cpos=146              'Put cursor in line 1, second last column, ready for next print
        char=cpos
        gosub wrins
    next
    goto main     'loop
wrchr:
    if char<255 then skipconvspc
    char=32
skipconvspc:
    gosub wrbyte        'Send High nibble and set up low nibble
    high rs            'Make sure RS is high
    pulsout e,1         'Pulse enable pin to send data.
wrins:
wrbyte:
    let pins = char/16    'High nibble of char to outputs 0 to 3
    pulsout e,1         'Pulse the enable pin to send data.
    let pins = char & 15  'Low nibble of char to outputs 0 to 3
wrbig:    'find start of definintion for 'bnum'
    numadr=bnum*4+64
    'write char out
    for defidx=0 to 3
        tnumadr=numadr+defidx
        read tnumadr,bchr    'read byte with next two halves of the line
        char=bchr/16-1       'write high nibble as CG
        gosub wrchr
        char=bchr & 15-1     'write low nibble as CG
        gosub wrchr
        lookup defidx,(64,20,84,0),coff
        char=cpos+coff
        gosub wrins
    next
    'restore to next position in line 1
    cpos=cpos-3
    char=cpos
    gosub wrins
Back
