yes, sorry...I couldnt find it and thought perhaps I had messed up posting.Is this the same question that was posted
23 03 at 19.33 ?
e.
Think racetrack scanner, w/ manual freq. adjust. Racetrack officials use the 450-470 Mhz FM range to transmit instructions to drivers.manuka has posted an answer on 23/3, but perhaps to rephrase the question he posed, are you working with voice or data? Are you wanting to listen to that whole band and tune a radio through that band manually, or do you want to use a picaxe to scan through CB channels, or do you want to send data at a frequency around 450-470Mhz?
