The piece of wire should be just fine. If you want to get technical, 1/4 wavelength would give you good performance. To get the length, you divide 234/Fmhz. This will give you the length in feet. I dont know the one for metric.
234/433=~6.5 inches (6.484988 inches to be exact). Half wave would be about 13 inches minus a few thousandths. Half wave=better than 1/4 wave. 25.9 inches will give full wave, even better performance, but it's gettin kinda long now.
Unless you have pretty specialized equipment, I wouldn't bother trying to get it exact to what it's supposed to be. Using 6.5, 13, and 26 inches respectively should be close enough.
The other thing is that as radio waves get higher in frequency, they get ALOT more finicky. The US navy communicates with it's submarines using frequencies so low thier wavelengths are measured in tens or hundreds of miles. These penetrate the earth and actually reverberate off the molten core and back out to the subs.
Good luck getting a signal of a few tens of gigaherz to even go through a tree or cloud, let alone a wall. It's all a compromise. 433 mhz isn't too bad, but it can be scattered and blocked depending on things like the material in it's surroundings, any EM fields, etc. placement can be jsut as important as the antenna or output power itself!
--Andy P
