BillyGreen1973
I'm just starting to design a 32 LED controller for an arcade machine project.
The 40x2 recieves data from the PC using 'serrxd' in the form of
identifer,byte1,byte2,byte3,byte4
It then simply loads the output ports with these bytes, thus controlling 32 leds.
The problem I'm having is this, when I simulate the code below, B.0 returns to an input after the serial data is recieved, even though it is set to an output in the 'init' section.
If I move the 'Let dirsB=255' line to after the Serrxd, all is fine.
I would prefer to keep the 'Let DirsB' command in the init section, just for neatness (it also may be a little quicker?), but what am I doing wrong?
I don't know if it is a code issue, or sim issue. (I dont have a 40x2 to try it on yet)
Thanks
Thanks
init:
#picaxe 40x2
let dirsA=255 ;set all ports to outputs
let dirsB=255
let dirsC=255
let dirsD=255
;requires 254 as identifer, receive 4 bytes into b0 to b3
serrxd (254),b0,b1,b2,b3
;load outputs with b0 to b3
outpinsA=b0
outpinsB=b1
outpinsC=b2
outpinsD=b3
