I've seen a few other people on the forums voicing similar problems with 40x1's.. i wonder if there is actualy a problem with a batch of them?
Ok, so i have an Axe022 board, i have two 40x1's and a 28x1 all bought from tech supplies recently. I run the protoboard on an adjustable 5v Switching regulated bench supply at 5.00v.
The 28x1 appears to work fine, i can write programs, download them to the chip, and run them.. when i click the firmware? button i get : "Firmware A.2 - Picaxe 28x1 (40x1) firmware version 2".
Currently i run the 28x1 with jumpers J4 and J5 in the right position, which tells the picaxe to use the fitted 4mhz resonator
So i know the usb cable/proto board is all working...
But, when i remove the 28x1, and install either of the two 40x1's, neither one will co-operate with me.
When i click the Firmware? button, i get a 'hardware not found on COM3' error (com3 is the USB cable serial interface). When i go to the USB test port dialogue, i see a controllable signal on pin 6 of the 40x1 which indicates everything is still ok as expected...
Needless to say, hitting F5 results in a hardware not found error...
My suspicion is that the 40x1's are either bad, or don't have the picaxe bootstrapping on them to understand whats going on... Its just odd, as they are brand new, and they came from tech-supplies.co.uk, picaxes' store as it were...
Does anyone have any ideas?
