I have a 08m2 Picaxe microcontroller on a protoboard that I am running at 5 volts with an ID-12 RFID reader. I would like to add a pager motor to the project board. I have a 3V Radioshack Vibration motor with a 95Ma current rating that I would like to add to the project. I know I cannot simply attach the motor to the picaxe because of the 20Ma pin limit so I will be using a transistor like this:
http://zootool.com/watch/yy42/
Since the vibration motor is 3V and the power supply is 5V can I just add a 22OHM 1/2 watt resistor between Voltage and the positive of the motor so I do not blow up the 3V motor? I want the motor to vibrate as much as possible and I want to make sure I am doing this correctly. This project is very small and I am trying to run off of only one power source.
Thanks You!!!!
Thanks You!!!!
