I'm trying to interface a 5Hz GPS (An MTK chipset iBlue 747) with a PICAXE-28X1 via the 'ser rx' pin. Ultimately the PICAXE will, with 100% reliability, relay the 115200 baud NMEA sentences (Just ASCII plain text) from the GPS to 'ser tx' (and consequently a MAX233) without any processing, and generate and transmit to 'ser tx' extra NMEA sentences based on data from an i2c compass, accelerometer and DS18B20 1-wire thermometer, all within the 80ms or so between the sentences from the GPS. (Yes, I'm fully expecting to have my expectations dashed, but there's no good reason not to be hopelessly optimistic!)
I believe the logic of the GPS is 3V, but I am underequipped to measure it accurately (I have only a multimeter with peak hold)
The sticking point at the moment is one of the first hurdles - how to convert the ~3V serial of the GPS to reliably interface with the PICAXE-28X1, currently on a regulated 5V supply. (There's no reason why the PICAXE supply can't be bought down - the minimum logic voltage for the MAX233 is 2V) I've seen several suggestions - transistor, mosfet, dedicated logic converter - but all were relating to comparitively low baud rates, and I'm not sure what the best course of action is for 115200 baud, which is after all asking quite a lot from the little PIC.
The question summarised, then: With reliability as the main objective, and with the serial stream purely transmitting from a 2.5 - 3V device to the PICAXE-28X1, what is the recommended way to interface the two?
