stocky6409
Hi all,
Playing with an idea for a project where I need to control/monitor multiple inputs and switch outputs via a WIRE connection.
I have seen a system on a peice of ag machinery where it has a 3 wire cable (+ve,GND, DATA) running between the control console and the high current relay box that I think will suit my needs but I'm stuck trying to reverse engineer the concept to work out what they may have done. Unfortunately i do not have easy access to the equipment to hack it, but I do know that both ends do talk to each other as there is a "comms failure" indicator that shows if there is a fault with the DATA wire.
Any bright ideas on how this may have been implemented? Cable is 3 core unsheilded cable - nothing fancy at all and runs in a very dirty/electrically noisy environment over distances typically 30+m with no probs at all!
PS - this wil use PICAXE at both ends - so its not totally off topic!
Stocky
Stocky
