Depends on what you mean by "simulatenously" ... the 14M can put the same PWM signal out of up to four pins and run another independant PWM as well, most other PICAXE's have a single PWM or two.
The 18X has just one PWM, that's down to the PICmicro 16F88 hardware. Take care reading the PICmicro datasheets because configuration fuses can route PWM to different pins but AFAIK only one or the other, that won't give extra PWM.
