3 * 16 lcd
kym
Looking for some information on this lcd or driver used ?
This looks like a 3 line *16 Character Display and is from a
Uniden Cordless phone Model XS 1215 .
Not sure of the Pinout or the driver chip used may use SPI or I2C protocol.
Still in the phone and it does work. TIA
A quick Google search on various phrases did not find any details on the LCD module.
Suspect you might not have much luck and do not recall that particular device being mentioned here in the past.
Your options may come down to:
1. Luck that some one finds specs
2. You try some careful trial and error test and do some circuit tracing before removal from handset
3. Buy an alternate device such as Nokia 3310 or Siemens A55 mobile which have been documented.
kym
Oh Google has failed me :mad: this time as well but this site has a lot of cellphone Pinouts
http://www.module.ro/
the only numbers on this module NCOG 305 and 6A23FFC which Google has no knowledge of either. :(
easy to solder contacts with separate leds for back-lighting and smaller than a Hantronix 2*16 display.
Thanks anyway ;)
