Not on the 28X2. Any pin can be an output, any pin an input. So there is no such thing as default outputs. high/low syntax changes toHigh and Low are output commands and only work on the default output pins.
So, High 1 raises Output 1/PortB pin 1 (that is physical pin 22) to a high state.
