thunderace7
Hi. I've a project using a 28x1 chip but I need another output pin and the 28x2 seems to use the serial out as an optional output. Can I use the 28x2 as a direct plug-in replacement for my 28x1 as it seems to be pin-compatible. I am using an external 4Mhz resonator for the x1 so I guess I must change the Pause commands accordingly as the x2 runs faster. I think I must also change pins commands to pinsb and set the direction of the A and B ports. Is there anything else I've missed?
Thanks.
Thanks.
