*** PICAXE-28X1 (40X1) ***
The PICAXE-28X1 (40X1) firmware is implemented on a PIC16F886 (PIC16F887)
BASE FIRMWARE CODE:A
V0 FIRST PUBLIC RELEASE. ROHS COMPLIANT
V1 CORRECTED ISSUE WITH OUTPINS AND END COMMANDS
V2 ENHANCED OPERATION OF @PTR, @PTRINC, @PTRDEC
V3 CORRECTED ISSUE WITH MISSING CENTRE '0' ON #VARIABLE WITHIN HSEROUT COMMAND
CORRECTED ISSUE WITH DISCONNECT FUNCTION DURING A COUNT COMMAND
CORRECTED ISSUE WHERE BACKGROUND FUNCTIONS COULD OCCASIONALLY CORRUPT SCRATCHPAD BYTES 15 & 79
CORRECTED ISSUE WITH SERRXD (NO TIMEOUT) NOT CORRECTLY OPERATING
RECALIBRATED SERIN COMMAND BAUD RATES FOR INTERNAL RESONATOR TO REDUCE USE OF CALIBFREQ
V4 CORRECTED INTERRUPT CONFLICT WITH USE OF HPWM/PWMOUT COMMAND
V5 CORRECTED ISSUE WITH SERVO/SERVOPOS COMMAND CAUSED BY V4 CHANGES
