If I issue a pwmout command on the 28X, does any pinsc command (or any output command that would affect the pin being used for PWM) stop the PWM execution?
For instance if I had:
'Start PWM output on portC, pin 0 (3.9kHz, 50% duty)
pwmout portC 1, 255, 512
...more code here
'Change portC outputs
pinsc = bportCDisp
where "bportCDisp" is any byte variable (0-255), would this set the PWM output pin to the value required for the byte, or would the PWM continue until another PWMOUT command?
I can't test it as my last 28X just died...
...more code here
pinsc = bportCDisp
