I have been programming/testing a 28X "in circuit", debugging sections of a main program.
Everything was going according to plan, when suddenly the 28X ceased responding to programming commands.
The last section of program under test is still working as required, but I can't get it to reprogram.
I was testing a simple routine for controlling 4 relays(via transistor buffers) thru standard Output pins.
I took it out of the circuit and tried to program it in my programming board - same result.
I have tried the hardware reset routine and also power up reset, but it refuses to work!
I also tried another 28X, and that programs normally.
The existing program continues to work OK, so the 28X is not damaged.
Is there any method that I can use to restore the programming function to normal?
kenmac
kenmac
