Chris DeHut
Hi all,
I am working on another high capacity I/O device using a 28X and MCP23017 chip. I did one already with the MCP23016 chip, but this time I want to make things much more compact and the 23017 seems to be much better laid out for this.
I want the system to work like this...
All inputs are switches connected to ground. So, when a switch is made, the signal at the port is pulled low.
For the electronics, I think I want this to be the configuration...
+5Vd --> 1K resistor ->|
Gnd -> Sw ->-----------| ----> 23017 port
Is this correct? Sorry, I am a bit better at programming than electronics.
Chris
Chris
