Mad Professor
Good Day All.
I think this might be over kill for a pic, as I am sure a timer like the 555 would be able to do what I am after, but it's been well over 10 years since I last used 555 chips.
I have posted over on allaboutcircuits.
I am trying to build a power shutdown circuit for a friend.
This circuit is going to be used in a vehicle, but it not going to be connected to anything important.
The problem he is having is that audio/video system does not always fully shutdown (turnoff), when it gets stuck like this it pulls aprox 1.5amps.
If the vehicle is used eveyday it is not a problem, but if the vehicle is sat still 2 or 3 days, the battery is to flat to start.
When the system does shutdown (turnoff) it only pulls aprox 0.10-0.15amps.
The vehicle in question runs on a 24volt system, compaired to a 12volt system.
The vehicle is fitted with a master battery kill box that will remove all power from the vehicle apart from the alarm system, it has a remote kill wire that just needs to be grounded to trigger the system.
So I need a way to kill all the power to the audio/video system, after a preset time, once the vehicle has been turned off.
I am now thinking if I should stick with somthing like a 555 timer, or use a Picaxe 08.
I know when anyone say anything regarding using a Picaxe ect in a vehicle, all hell brakes lose.
I would like your thoughts and sugestions
Thanks for your time.
Best Regards.
Best Regards.
