I'm trying to get ready for this season's gardening. We had great luck last year with an EarthBox growth system (you can also make these from scratch) but one downside was the need to refill the reservoir at least daily. That's no problem unless you would like to go away for a week or two on vacation.
You can see where this is going...
Others have developed automatic watering systems (an example here) but all seem to hook into their residential water system. I'd like to use a rain barrel as the water source and automatically control a water valve with a Picaxe. 24VAC solenoid valves are often used in lawn watering systems and they are reasonably inexpensive. I noticed that valve manufacturers typically specify a working pressure range of about 15-150 psi (~100-1000 kPa for those living in civilized nations). Does anyone here have working knowledge of those valves? Do they work with low water pressure such as might be found at the bottom of a half-full rain barrel (e.g. <1-2 psi)?
Sure, I could put the barrel on the roof but...
