As I see it you have a couple of options/steps:
1. Test the program first on a breadboard with the 40X1 and an EEPROM. Start with the simple code hippy has posted. Verify/prove operation on the breadboard first.
2. Verify if there is a board fault as discussed so far and if so, carefully cut the tracks on the board between the RTC and EEPROM and use a couple of fine wires to reconnect, Then again test the program with the 40X1 and an EEPROM.
3. Insert all of the chips and test one at a time
4. Decide if you are going to make a new PWB/PCB. If so the repeat step 3 on the new board
5. Develop your final datalogger program
