Well this is one of the easiest games to play, requiring only a voice. So here is a version on the PICAXE.As always there are instructions in the program and all Comments are welcome.
__________________________________________
[SIZE=2][SIZE=2][SIZE=2];*************************************
;* 21 *
;* The easiest game ever? *
;*************************************[/SIZE]
[SIZE=2];21 is very much like Blackjack (which I will make at some
;point), each player takes it in turns to add 1, 2 or 3 to
;the a number starting at 0; the person that says 21 is the
;lo(o)ser
;To play you need a 20x4 serial LCD connected to pin B.6 of a
;PICAXE 20X2 (To simulate goto Options>>Simulation>>Simulate
;Serial LCD with 'serout' commands on output: and change the
;pin name to B.6) and a keyboard or Numpad connected to C.1 and
;C.2.
#picaxe 20X2
;Use the number keys to enter the amount you wish to add or
;to make a menu selection. Enter confirms.
;You may have as many players as you like but 255 players
;does make for a boring game for at least 234 of them...
;[/SIZE]
[SIZE=2];
;*REVISIONS: *
;*#Created: 3.8.11 *
;*#Completed: 10.8.11 *
;************************************[/SIZE]
[SIZE=2]SYMBOL thenumber=b0
SYMBOL players=b1
SYMBOL looper=b2
SYMBOL PICAXEon=b3
SYMBOL char=b4
SYMBOL temp1=b5
SYMBOL target=b6
SYMBOL curplayer=b7
SYMBOL lgtemp=w4
SYMBOL temp2=b10
SYMBOL true=1
SYMBOL false=0
SYMBOL round=b11
target=21
curplayer=0[/SIZE]
[SIZE=2]
init: 'Get amount of players
serout B.6,N2400,(254,128)
serout B.6,N2400,("How many players?")
kbin char
if char<>$5A then
read char,char
players=players*10
players=players+char
serout B.6,N2400,(254,192)
serout B.6,N2400,(#players)
loop until char=$5A
'Should the computer play?
serout B.6,N2400,("Should PICAXE play?")
serout B.6,N2400,("1) Yes")
serout B.6,N2400,(254,148)
serout B.6,N2400,("2) No")
kbin char
if char=$16 then
PICAXEon=true
PICAXEon=false
'Setup gameboard
serout B.6,N2400,(254,1)
serout B.6,N2400,(254,149)
serout B.6,N2400,("X")
serout B.6,N2400,(254,139)
temp2=curplayer+1
serout B.6,N2400,("Player:",#temp2)
'Play!
main: curplayer=curplayer+1
if curplayer>players and PICAXEon=true then
'Computer
random lgtemp
temp1=lgtemp/21845
'Human
kbin temp1
select temp1
case $16
temp1=1
case $1E
temp1=2
case $26
temp1=3
endselect
sertxd ("h: ",#temp1)
if curplayer>players then
curplayer=0
'Display
serout B.6,N2400,(254,146)
temp2=curplayer+1
serout B.6,N2400,(#temp2)
temp2=thenumber+temp1
for looper=1 to temp2
if looper=11 then
if looper=21 then
serout B.6,N2400,("#")
next
thenumber=thenumber+temp1
'Result Check
if thenumber>=target then
goto lose
goto loose
wait 1
'Lo(o)se Routine
loose:
lose: serout B.6,N2400,(254,1)
serout B.6,N2400,(254,195)
serout B.6,N2400,("You are out!!!")
wait 3
dec players
serout B.6,N2400,("Round: ",#round)
wait 1
serout B.6,N2400,(254,212)
serout B.6,N2400,("Players: ",#players)
wait 3
inc round
'Chart to understand keys
EEPROM $45,(0,9)
EEPROM $16,(1)
EEPROM $1E,(2)
EEPROM $25,(4,3)
EEPROM $2E,(5)
EEPROM $36,(6)
EEPROM $3D,(7,8)[/SIZE]
[/SIZE][/SIZE]
