High, just wondering if someone can shed any light on this one ...
I successfully program a 20M2 and it runs fine until I disconnect the programming cable. The 10K/22K resistors are still in circuit after the cable is removed. I'm using the standard 10K/22K resistor setup and have used this for years on all sorts of picaxe projects without any issues. I noticed that shorting the 22K resistor fixes the problem. I measured the dc voltage (using a high impedance DVM) on the serial input pin and noticed it was sitting at about 2V (22k un shorted) and less than 1V (22k shorted). Seems like the chip is pulling the serial input pin high. I think I have a dud chip but seems funny that it still works with the programming cable connected. Any similar experiences ?
