#PICAXE 20M
To program for the PICAXE-20M, either add the "#Picaxe 20M" directive in your code as suggested by SilentScreamer or use the menu option View -> Options -> Mode to select the 20M.I can not see how to use the latest edition of the programming software to work with a 20M chip?
One that I and several others have used.OK, I thought some time ago I upgraded to the latest version. Just checked now, and the upgrade appears not to have worked. Have downloaded Patch522 and tried to install it.
Gets as far as the Modify/Repair/Remove screen, and then the choices (LH) area of the next screen is blank. After "Next", it goes off and does something and then "Finish". Even after rebooting, the "About" still shows 5.1.6 when I restart the Editor. Using Windows XP, Service Pack 3.
Suggestions?
Thanks in advance.
