I have before seen Plx-daq ,and been interested in it, but can't use it, because I have Open Office in my laptop, not Exel. That's why I haven't downloaded it...
Anyway, Your question made me curious, it would be nice to also SEND data to Picaxe from the Plx-daq, and to find out, I downloaded it.
Read through the introductions, but found NO reference to SENDING data out.
In the example codes there were lines, where the processor reads something (seems a timer setting) from Plx-daq. I did not see there a way of sendin commands to Picaxe...
There were mentioned "check boxes", which can be recognized by Picaxe, but I think that those can't be used for sending data, because the "boxes" have some effect to Plx-daq ,too.
Would You care to tell, where did You get the knowledge, that data could be sent from Plx-daq to Picaxe?
(normally ,one could sent commands to Picaxe using terminal, but unfortunately one can NOT use two different programs at the same time, which uses the same com-port...)
Well, not possible to send data from Plx-daq , maybe have to set up another com port to send data to Picaxe...
OR tinker with Plx-dac's code... is it open...
