This is an easy project to probe your wood stove for instance. Bells and whistles could easily be added. Alarms for time to add wood or whatever.
It works well and I'm just putting it out there for anyone interested.
Paul
Paul
' Picaxe 18X to Max6675 thermocouple amp with C to F conversion.
' Good for a range of temperatures fron zero to about 1300 degrees f. Use type K or N thermocouple.
' Paul Tribbey Superior, WI 3-1-2009. Free to use for everyone.
' Some code inspired by PH Anderson.
' Connect thermocouple to pins 2 and 3 of Max6675.
' Using PH Anderson 118 serial LCD display on output 0. Easily modified for other display.
Symbol CS = Output4 ' connect to pin 6 MAX6675
Symbol SCK = OutPut5 ' connect to pin 5 MAX6675
Symbol MISO = Input1 ' connect to pin 7 MAX6675
Symbol Val = W1
Symbol Dig = B4
Symbol I = B5
Symbol J = B6
Main:
GoSub MeasTemp
GoSub DisplayTemp
Pause 1000 ' allow Max6675 to finish
Goto Main
MeasTemp:
High CS ' deselect the 6675
Low SCK
Low CS ' start conversion
Val = 0 ' initialize temperature variable
For I = 1 to 16 ' serial clock in 16 bits
High SCK
Val = Val * 2 + MISO 'clock in the bits into a word
Low SCK
Next I
Val = Val / 32 ' use only the 11 most sig bits
Val = Val * 9 ' quick and dirty celcius
Val = Val / 5 ' to farenheight
Val = Val + 32 ' conversion
Return
DisplayTemp:
Serout 0,t2400, ("?f") ' PH Anderson LCD #118 on output 0
Dig = Val / 1000 ' thousands
Serout 0,t2400, (#Dig)
Val = Val % 1000
Dig = Val / 100 ' hundreds
Val = Val % 100
Dig = Val / 10 ' tens
Val = Val % 10
Dig = Val ' units
Return
