Hi all, I'm trying to use a standard 18x project board with onboard UL2803 darlington npn array to light some LEDs.
The LEDs are packaged in a button circuit board and have surface mount resistors so I'm not sure their values. I know that if 12v are applied they light up (with no heat issues). The three resistors have a common ground.
My question is, how would I wire the outputs of the UL2803 to control a common ground. I know usually I would connect 12v to the LED (via proper resistor) and the ground wire of the LED to the UL2803 output but I can't do this in this case because of the common ground between the three LEDs.
Help please!
Help please!
