18m2 touch a potential solution to fuel out sensor?
An ongoing project on my back burner is determining if fuel is flowing through a line (or present within a fuel line) without physically interrupting/breeching/penetating the line.
Basically a sensor that warns when the fuel has run out (the feed line is empty).
I remember there being some discussion of using a capacitance sensor to do this. It now occurs to me that the 18m2, with its touch sensors, might fill this need.
I believe the fuel tube is a "rubber" tube, but it could be metal (I can confirm with the end user). Anyway, I would think that the capacitance would change as the tube is full or empty, would it not? Would you just need a wire or plate wrapped around the outside of the tube (or if metal, attached to it?
Am I totally off-base or getting close to a possible solution?
Cheers,
Wreno
Cheers,
Wreno
