This simple little serial menu program works correctly in the simulator, but when the 18M2 runs it, the select case always defaults to "Not Valid"
sertxd("1. test1",cr,lf)
sertxd("2. test2",cr,lf)
sertxd("3. test3",cr,lf)
sertxd(cr,lf,"Choose...",cr,lf)
get_in:
serrxd b1
select b1
case 1
sertxd("You chose 1",cr,lf)
case 2
sertxd("You chose 2",cr,lf)
case 3
sertxd("You chose 3",cr,lf)
sertxd("Not Valid",cr,lf)
endselect
