I'm just going to start playing around with the touch function on an 18m2 but would like some advice/clarification around the touch pad.
The data sheet states that a touch pad can be created using a 20mm copper shape on a pcb as long as the pad is isolated from the finger by 2mm of plastic.
So the question is....
can the pcb be used as the isolation material, eg: 20mm copper pad on the copper side of the pcb and the touch zone on the other side of the pcb above the copper pad ?
Rgds all,
Sid
Rgds all,
Sid
