Hi Picaxers,
I’m hoping someone maybe able to offer some suggestions to correct the sporadic resetting of a 14m2. I made this circuit some time ago and have no diagram for it and it is installed in a difficult spot to access. I am aware without a c.d this is a long shot but I have noted the following behaviour. When I have the data cable connected it works flawless. I trialed removing each connection (ser in, ser out, 0v) and found that the combination of both ground and ser in connected makes the circuit run perfect. All other combinations have no affect on the resetting behaviour. I know for a fact the ser in has the correct resistor to ground. Maybe one of you experienced picaxers can think of a likely suspect? I also tried setting pins with dirs c and b and pulling up the unused pins but I couldn’t tell if that made a difference… any suggestions appreciated!
Thanks
Ant
Thanks
Ant
