Bob Champagne
First let me say that before discovering this site I knew absolutely nothing about microcontrolers, but after reading and reading the so many informative posts, I have now completed several simple Picaxe projects. Thanks all.
Now the question: I have a VTT with heated grips that I control the temperature with a selfmade PWM circuit, instead of the usual LOW-HIGH switch. But the voltage from the alternator varies with the RPM of the motor between 12.4 and 14.2 volts, and so does the temperature of the grips. Is there a way to get a stabilized 12 volts using a Picaxe?
Thanks in advance, Bob.
