joliebrise
Never having used a H-Bridge driver before, I produced a circuit diagram from various sources.
MFA 919D motor drawing 1.5A @ 6v.
1.2v Voltage drop across L298
Tony
- Is it correct?
- Is it necessary to ground both sensor pins 1 and 15?
- What do you think about Alan Bond's addition of a 220R to reduce motor noise on the negative rail?
- He also suggests adding a transistor into the input line to clean up the signal as there are problems with 2.4GHz. How do you do this as there are no circuit diagrams?
Tony
