Hi
I need to use a 08M2 to drive a magnet on a pinball on a home made pinball. These magnets run extremely hot if constantly "on" cooking the playfield and eventually tripping the ,magnets protection thermal . So the comercial pinball systems use a PWM to help run them a bit cooler.
The cycle would be extremely slow, maybe 1 or 2 short pulses per second.
Is it possible to run the PWM at that lower a cycle rate? and if so what would the code be?
Can you please let me know what you think?
The magnet is run off an 8 FET array that can handle the current and wattage loading required for the magnet. The 08M2 will output into a buffer chip that then runs the FETS.
Regards
G
Regards
G
