08m2 Dice game
mark Easterling
I am using the code below on a 08M2. The circuit runs well for about 10 seconds then goes wrong and flashes the LED's on/off very quickly and that all it does? Can anyone help please?
symbol z = w6
init: let dirs = %00010111
label0:
Switch off 4
Switch off 2
Switch off 1
Switch off 0
pause 200
Switch on 4
Switch on 2
Switch on 1
Switch on 0
pause 200
random z
if Input3 is On then label0
if z > 55000 then label1
if z > 44000 then label2
if z > 33000 then label3
if z > 22000 then label4
if z > 11000 then label5
Switch on 4
Switch off 2
Switch off 1
Switch off 0
label6:
pause 2000
goto label0
label5:
Switch off 4
Switch on 2
Switch off 1
Switch off 0
goto label6
label4:
Switch on 4
Switch on 2
Switch off 1
Switch off 0
goto label6
label3:
Switch off 4
Switch on 2
Switch on 1
Switch off 0
goto label6
label2:
Switch on 4
Switch on 2
Switch on 1
Switch off 0
goto label6
label1:
Switch off 4
Switch on 2
Switch on 1
Switch on 0
goto label6
hex
Active member
Works OK for me...
Try changing :
if Input3 is On then label0 ; keep fast-flashing all LEDs till input 3 low
for:
if Input3 is Off then label0 ; keep fast-flashing all LEDs till input 3 high
Like this:
C:
; random die roll program found on forum
; PICAXE 08m2 with button on input 3
; press button to take input 3 high and stop die from rolling
; LED pattern - on to light LED(s)
;    2   1
;    0 4 0
;    1   2
symbol z = w6
init:
    let dirs = %00010111           ; 0, 1, 2, 4 outputs for LEDs
    Switch off 4                   ; all LEDs off for 200 ms
    Switch off 2
    Switch off 1
    Switch off 0
    pause 200
    Switch on 4                    ; all LEDS on for 200 ms
    Switch on 2
    Switch on 1
    Switch on 0
    pause 200
    random z                       ; get random number 0 to 65535
    if Input3 is Off then main     ; keep fast-flashing all LEDs till input 3 high
    if z > 55000 then pattern6     ; select pattern 1 to 6 randomly
    if z > 44000 then pattern5
    if z > 33000 then pattern4
    if z > 22000 then pattern3
    if z > 11000 then pattern2
    Switch on 4                    ; pattern for "one"
    Switch off 2
    Switch off 1
    Switch off 0
Displaydie:
    pause 2000                     ; display LED pattern for 2 seconds
pattern2:
    Switch off 4                   ; pattern for "two"
    Switch on 2
    Switch off 1
    Switch off 0
    goto Displaydie
pattern3:
    Switch on 4
    Switch on 2
    Switch off 1
    Switch off 0
    goto Displaydie
pattern4:
    Switch off 4
    Switch on 2
    Switch on 1
    Switch off 0
    goto Displaydie
pattern5:
    Switch on 4
    Switch on 2
    Switch on 1
    Switch off 0
    goto Displaydie
pattern6:
    Switch off 4
    Switch on 2
    Switch on 1
    Switch on 0
    goto Displaydie
