Hi all. I have been making r/c led lighting circuits which are turned on or off via a spare r/x channel PPM pulse
Here is an example of code to detect an on pulse greater than 170ms using an 08M pin 4
start:
pulse:
pulsin 3,1,b2 ; read pulse on pin 4
if b2 < 170 then pulse ; if pulse is less than 1.7ms then go back to pulse and read again
if b2 >= 170 then go ; if pulse is greater than 1.7ms goto go start running led flash pattern
go:
'flashing program here
goto pulse ;go back to pulse and make sure state has not changed.
It can often be a pain having to plug in a spare rx and setting the transmitter up just to test the circuit.
I tried to write a short code after looking at data sheet for a 08M to generate a pulse to drive the input pin of the circuit to be tested:-
start:
pulsout 4,180 ;generate a pulse of 1.8ms on pin 3 08M
pause 20 ; wait 20ms
I know its rough. Tried it but it did not work. Not got access to a scope but logic probe was pulsing away on pin 3. Put the r/x on instead and it worked.
I must be overlooking something obvious. Scratching my head.
Any ideas anyone.
cheers
Ash
start:
pulse:
go:
start:
Any ideas anyone.
cheers
Ash
