08M leg 7 out 0 usage
RadioBob
I am trying to output to leg 7 out 0. I can manipulate with high and low command, but cannot use pin0 as I would like to. Problem is using piezo speaker and wish to drive between two output pins to effectively increase voltage across the device. I have output on pin4 and wanted to use a command like pin0=pin4 xor $1 to make pin 0 the complement of pin 4.
Any suggestions? I am using pin1, pin2 and pin3 as inputs. I have thought of a transistor "invertor" driven by pin4 and connecting the piezo across the input and output of the invertor, but that is extra circuitry. Alternately, I have considered a cmos NAND gate or cmos invertor chip, but that adds more complexity. I really would like to do it within the 08M chip if at all possible. I have VERY little program space left -- not enough to use high and low and an if statement to check pin4.
Thanks for any suggestions.
External logic or bit-banging are your only practical options. If you are out of program space there's only really the option of external hardware.
#Picaxe 08M
SetFreq M8
Low 4
Do
For w0 = 0 to 1000 ' Lower volume
pins = %00001
pins = %00000
Next
For w0 = 0 to 1000 ' Higher volume
pins = %00001
pins = %10000
Next
Loop
vttom
Exactly how does driving it from 2 pins get you more voltage drop compared to driving one side from the PICAXE and tying the other side to GND or VDD?
RadioBob
Why the voltage is effectively doubled
Well, the piezo goes from 4.5 v (say pin 4) to gnd (on say pin 0), then by switching the 4.5 v to gnd and the gnd to 4.5 v, you have swung the piezo across 9 v as far as its inputs are concerned. This is twice the swing that you can get from one pin and gnd. I hope this explains what I am trying to achieve.
Bob
RadioBob
#Picaxe 08M
SetFreq M8
Low 4
Do
pins = %00001
pins = %00000
Next
pins = %00001
pins = %10000
Next
Loop
Well, I'm not completely out of program space -- but I only have about 5 bytes available. If I could address pin0, I have enough space to xor with pin4 I think, but pin0 doesn't seem to be defined as pin1 through pin4 are. That is what I am seeking -- some way of manipulating pin0 with logic, not just low pin0 or high pin0.
I must admit, I don't see that the program provided gives me any insight into my problem. Did I miss something? Can I set "pins=pin4 xor %00000001" to set leg 7 to complement of pin4? This passed syntax check but unfortunately exceeded the program space left!
Thanks for the info!
Bob
outpin0=pin4 xor $1
Technically this shouldn't work, as it is reading the state of the pin 4 input buffer, which is not theoretically the same as the state of the pin 4 output driver. But in practice it does often work as the input buffer drifts to whatever the output buffer state is -try it!
RadioBob
Thanks, Technical. Good idea, but I'm afraid I didn't have enough memory left for that even. I guess I am back to a hardware solution -- either a single transistor and a couple resistors, or a cmos NAND, NOR or inverter gate. It means modifying my board a bit to add this -- I was hoping to achieve it in software and leave the board the same. This is for a morse code practice set for my amateur radio licensing class.
Thanks all that responded!
Bob VE3SUY
vttom
Bob
Oh, I get it. Technically, you're not really increasing the swing to 9v. When 1 pin is hard-wired to VDD or GND, then you're driving it on/off/on/off. With both pins are driven differentially, then it's going forward/reverse/forward/reverse. What you're really doing is doubling the duty cycle.
@ vttom. The voltage swing is doubled, the duty remains the same.
It's an age old classic method of quadroupling the power output.
@VE3SUY.
Adding a single inverter (possibly using a NAND or similar) is your best. It could be done with a single transistor but just one transistor would only be able to conduct in one direction. Drive in the other direction would be limited to whatever you used as a pull-up load resistor. That would impact on your total available power and also be quite inefficient. To build a full inverting totem-pole output stage with descrete trnaistors would use more board space than adding a 14-pin gate/inverter chip.
It is possible to get single gates in very small SMD packages.
