The only explanation I could find on inputs was this from manual 1 - "Inputs:
An input should be above (0.8 x power supply voltage) to be high, below (0.2 x
power supply voltage) to be low. It is recommended, but not essential, to tie
unused inputs low via a 10k resistor."
If I wanted to wire a push button to an input, should I go between the pin (say 3 for example) and the +volts rail?
Thanks
Paul
Thanks
Paul
