' Simple Diesel engine sound
' G. Hunter, Feb 05
' * 6 different steps of rate of sound between stopped and max speed.
' * Constant "fast idle" when decelerating until speed falls below '60' or 40% of max.
' * Double Horn blast on starting.
' * Random single horn when running - every 2 mins at max speed, longer times at slower speeds.
' * Brake exhaust sound on stopping.
' Analogue input voltage is on pin1 - arrange resistor divider to give 3.3V at max speed (3.3V = 160).
' Uses 5-stage shift register with bits 4 & 5 XORd and fed back to input bit.
' pin1 (adc1) is speed volts input
' pin2 (out2) is amplifier output.
' b0 is the shift register
' b2 is ADC voltage representing speed
' b3 is timer to determine rate of sound (pause).
' b4 is intermediate value for speed/10
' w4 (b8 & b9) is random number used to sound horn 'randomly'
symbol seed = b0
symbol speed = b2
symbol oldspeed = b5 'last speed reading, used to determine if changing
symbol decel = b7 '1 = speed is falling, 0 = accelerating or constant
seed=56 'initialize - can be any number except 0 and 255
'53 is slow, 36 is fast, 56 is pulsy fast
'4,9 are fast, 5 is pulsy
start:
seed = seed * 2 'shift left 1 bit. R/H bit 0 is set to zero automatically
if bit4 <> bit5 then xored 'do an XOR on bits 4 & 5 of seed (b0)
low 2 'speaker output
bit0 = 1 'feedback to R/H bit
goto motspeed
xored:
high 2 'speaker output
motspeed:
random w4 'for horn
readadc 1,speed 'read speed into b2 - 15 steps of 'speed'
if oldspeed = 0 and speed > 0 then Horn2
horn0:
if w4 > 65500 and speed > 11 then horn1 '65500 works every 2mins or so at max speed
'sometimes get 2 or 3 blasts together - just depends
'on random number generator.
if oldspeed > speed then slowing
if oldspeed = speed and decel = 1 then slowing
' So must be accelerating or at steady speed but was last accelerating
accel:
decel = 0
loop:
oldspeed = speed
b4=speed + 30/31 'integer result converts 16 steps of speed to 6
table: 'determine the 'clocking rate'
lookup b4,(18,10,7,4,2,1,0),b3 'idle + 6 steps of speed
'only enough memory for 6 steps in lookup table
paus:
pause b3
goto start
horn2:
sound 2,(57,50) 'starting double horn blast
pause 200
horn1:
sound 2,(57,150)
oldspeed = speed
goto loop
slowing:
decel = 1
if speed = 0 and oldspeed > 10 then juststopped
if speed < 60 then loop
b3 = 8 'decelerating at higher speeds gives constant 'fast idle'
oldspeed = speed
goto paus
juststopped:
pause 500
sound 2,(253,200) 'exhaust brakes sound - try 249 for a quieter hiss
goto loop
