peter howarth
do lcd displays work similar to a 4516 , you load bcd into the load input pins , take a pin high or low, and then the 4516 counts up or down from the loaded value, in other words does an lcd accept bcd data into either 4 or 8 inputs, then write/load data by taking another pin of the lcd high or low, the lcd stores it then displays the ascii character, or is it a whole lot more complicated than this
