WORD variables in Serial Terminal Simulation
#1
Hi everyone,
Yet again I feel stupid not being able to workout how to operate something simple.
I am trying to test some code with the simulator in PE6.
My code...
blah
blah
blah
SERIN C.3,N4800,W1
Serial Terminal Simulation window pops up when it hits my SERIN line and now I want to have '12345' pop into W1 of the 'Code Explorer' after typing it into the Transmit Buffer.
How on earth do I do this?
With 'Raw' selected, all it has is Transmit Buffer:(e.g "Value=",$25,13,10) as any form of example. But nothing works correctly for me.
I have tried:
"12345"
"Value=12345"
With ASCII selected:
12345
also doesn't work correctly.
Seems like something so damn simple, but ya think I can get the result I want... Nope!
Regards,
Mort.
#2
SERIN to a variable without a # only reads byte values, and only stores byte values, even if put into word variables.
Four options -
Either use 'SERIN C.3, N4800, #W1', or 'SERIN C.3,N4800,B3,B2',
Or just replace it with 'LET W1=12345',
Or with 'COUNT C.3,W1' and adjust the value which will be read using the Simulation panel, Values tab, bottom left of PE6.
Useful tip -
#IfNDef SIMULATING
  SerIn C.3, N4800, w1
#Else
  w1 = 12345
#EndIf
#3
Four options -
Useful tip -
#IfNDef SIMULATING
#Else
  w1 = 12345
#EndIf
Hi Hippy,
Thanks for the reply. I think you misunderstood what I was asking. Basically how can I type 12345 as a WORD variable value into the simulation terminal so that when running a simulation, my SERIN command takes in my number 12345 and puts it into W1 in the Code Explorer.
#4
You cannot. Your "SERIN C.3,N4800,W1" command will not accept a word value input, in simulation or when running on a real chip.
