Wireless Question
Wombat_In_Space
I am hoping there is an easy answer to this question I am building a 14m&433Mhz remote hand pad which I want to switch a second 2 Picaxe 28x chips outputs high or low. I am use to using serout & in with the data logger to the LCD.
I have read through Hippies wireless page and search through the forum I am more looking for a confirmation of the exact code.
I can get the code Hippy wrote to work and output to a LCD on the 28X now I want to start controlling the pins.
Thanx in advance
moxhamj
Which bit do you need - the wireless code or the LCD code? If you already have the LCD working as you say then you are well on the way. The wireless part is quite easy - see http://picaxe.orcon.net.nz/433rpt.jpg for a repeater circuit but you can leave the middle repeater circuit out and just build a transmitter and receiver. The code is only a few lines.
Build it in stages on a protoboard - eg get the wireless working as one project, then the LCD then put it together.
Wombat_In_Space
I can get the wireless sending text for the LCD writing thats no prob Hippies code does that no probs. I am have trouble working out how to make it switch pins hi and low on the receiving chip.
Eg; press button on hand pad which is to switch output 0 high
steliosm
Well, you need to define a protocol for doing that.
What you have now, is passing the raw data received to the LCD module. You need to use a simple way to identify the 'message' type.
What I would do, would be to also send another byte in the beginning along with the text which will indicate what I want the receiver to do. On the receiver you can check the value of that specific byte and act accordingly.
Wombat_In_Space
Trying to find 11 bytes
Here is the code for the transmitting picaxe I have worked out the receiver side now I have a problem with the TX I need to find 11 bytes :-( so the code will fit on a 14M chip. here is the code. I am not very good at optimizing code I normally go to a bigger chip.
Thank you for any help in finding these 11 bytes.
BCJKiwi
You could try this for starters;
'****      Wireless Hand Pad TX For Telescope       ****
'****  Control System Ver 1.0a       ****
'****  Written By Darren Quinert      ****
'****  © DP & TL Computers 2000-2008      ****
'****      Parts of this code was obtained     ****
'****    from         ****
'**** [URL]http://www.hippy.freeserve.co.uk/picaxewf.htm[/URL] ****
'****    Picaxe 14M and 433 Wireless        ****
'****    Module         ****
#PICAXE 14M
setfreq m8
SYMBOL  RECEIVER_CODE   = 1 ' 0 .. 15
SYMBOL  SENDER_CODE     = 1 ' 0 .. 15
SYMBOL  TX_PIN          = 0
SYMBOL  TX_BAUD         = 2400
SYMBOL  TX_LED  = 1
SYMBOL  POWER_ON_PIN    = 2
SYMBOL  POWER_UP_DELAY  = 20
SYMBOL  POWER_UP_LED = 3
SYMBOL  SIDERIAL_RUN = 4
SYMBOL  PREAMBLE_LENGTH = 5
SYMBOL  MAX_DATA_LENGTH = 4
SYMBOL  PREAMBLE_BYTE   = $AA
SYMBOL  SOM_BYTE        = $C5
SYMBOL  EOM_BYTE        = $5C
SYMBOL  POSTAMBLE_BYTE  = $3A
SYMBOL  dataLength      = b0
SYMBOL  byteNumber      = b1
SYMBOL  bytePtr         = b2
SYMBOL  byteo           = b3
SYMBOL  bit             = b4
SYMBOL  k               = b5
SYMBOL  crc             = b6
SYMBOL  POLYNOMIAL      = $8C
Powerup:
 let dirsc=%00000001
 PAUSE 5000
Main:
 let pins =%00000
 if pin1=1 then let b7="1" : goto createpacket :endif 'CreatePacket1
 if pin2=1 then let b7="2" : goto createpacket :endif 'CreatePacket2
 if pin3=1 then let b7="3" : goto createpacket :endif 'CreatePacket3
'****   Checks 3 Position Switch ****
Checksw:
        if portc pin1=1 then let b7="4" : goto createpacket :endif 'CreatePacket4
        if pin0=0 then Decroutine
        if pin0=1 then Focus
       if pin1=0 then let b7="0" : goto createpacket :endif 'CreatePacket0
     GOTO Main
'****   Checks 2 Position Switch ****
Decroutine:
   if pin4=1 then let b7="5" : goto createpacket :endif 'CreatePacket5
        if portc pin2=1 then let b7="6" : goto createpacket :endif 'CreatePacket6
        if pin4=0 then Main
Focus:
        if pin4=1 then let b7="7" : goto createpacket :endif 'CreatePacket7
        if portc pin2=1 then let b7="8" : goto createpacket :endif 'CreatePacket8
        if pin4=0 then Main
'***** Create Control State Packet ****
CreatePacket:
        dataLength = 1
        POKE $50,b7
        GOTO Send
#rem
CreatePacket0:
        dataLength = 1
        POKE $50,"0"
        GOTO Send
CreatePacket1:
        dataLength = 1
        POKE $50,"1"
        GOTO Send
CreatePacket2:
        dataLength = 1
        POKE $50,"2"
        GOTO Send
CreatePacket3:
        dataLength = 1
        POKE $50,"3"
        GOTO Send
CreatePacket4:
        dataLength = 1
        POKE $50,"4"
        GOTO Send
CreatePacket5:
        dataLength = 1
        POKE $50,"5"
        GOTO Send
CreatePacket6:
        dataLength = 1
        POKE $50,"6"
        GOTO Send
CreatePacket7:
        dataLength = 1
        POKE $50,"7"
        GOTO Send
CreatePacket8:
        dataLength = 1
        POKE $50,"8"
        GOTO Send
#endrem
'**** Send Data Packet *****
Send:
        ' On entry, 'dataLength' contains the number of bytes
        ' of data to send. The bytes of data are stored in SFR
        ' RAM from location $50 upwards.
CalculateCrc:
        crc = 0
        byteo = SENDER_CODE * $10 | RECEIVER_CODE
        bytePtr = $50
        FOR byteNumber = 1 TO dataLength
          PEEK bytePtr,byteo
          bytePtr = bytePtr+1
          GOSUB CrcAdd
        NEXT
PowerUpTransmitter:
        HIGH POWER_ON_PIN
   HIGH POWER_UP_LED
        PAUSE POWER_UP_DELAY
SendPreamble:
   TOGGLE TX_LED
        FOR byteNumber = 1 TO PREAMBLE_LENGTH
          SEROUT TX_PIN,TX_BAUD,(PREAMBLE_BYTE)
        NEXT
SendStartOfMessage:
   SEROUT TX_PIN,TX_BAUD,(SOM_BYTE)
SendReceiverAndSenderCode:
        SEROUT TX_PIN,TX_BAUD,(byteo,datalength)
'SendDataLength:
'   SEROUT TX_PIN,TX_BAUD,(dataLength)
SendData:
   TOGGLE TX_LED
   bytePtr = $50
          PEEK bytePtr,byteo
          bytePtr = bytePtr+1
          SEROUT TX_PIN,TX_BAUD,(byteo)
        NEXT
SendChecksum:
        SEROUT TX_PIN,TX_BAUD,(crc,EOM_BYTE)
'SendEndOfMessage:
 '       SEROUT TX_PIN,TX_BAUD,(EOM_BYTE)
SendPostamble:
   TOGGLE TX_LED
        FOR byteNumber = 1 TO MAX_DATA_LENGTH
          SEROUT TX_PIN,TX_BAUD,(POSTAMBLE_BYTE)
        NEXT
   GOTO Main
CrcAdd:
      FOR bit = 0 TO 7
       k = byteo ^ crc & 1
       IF k = 0 THEN CrcAdd1
       k = POLYNOMIAL
      CrcAdd1:
       crc = crc / 2 ^ k
       byteo = byteo / 2
      NEXT
 RETURN
Added the #PICAXE 14M and moved the setfreq to the top.
Added a next in one of your lower for .. next loops
Since only the $50 memory location was used for all 8 conditional tests, presumably only one is active per pass so replaced all the gosubs/subroutines with direct writes to $50.
At a quick glance this would appear to be logically the same.
Code now 248 bytes.
Wombat_In_Space
BCJKiwi thank you for the edited version I had to make some small changes to it to get the correct reaction from the switches. The changes you made showed me a different way of doing things.
'****                from                    ****
'**** http://www.hippy.freeserve.co.uk/picaxewf.htm    ****
'****            Module                        ****
#PICAXE 14M
setfreq m8
SYMBOL  TX_PIN          = 0
SYMBOL  TX_LED  = 1
SYMBOL  bytePtr         = b2
SYMBOL  byteo           = b3
SYMBOL  bit             = b4
SYMBOL  k               = b5
SYMBOL  crc             = b6
Powerup:
 let dirsc=%00000001
 PAUSE 5000
Main:
 let pins =%00000
     if pins=%01000010 or pins=%01000011 then Emergency
     if pins=%01000000 then poke $50,"4" :endif     'CreatePacket4
     if portc pin1=0 then poke $50,"0" :endif     'CreatePacket0
     if pin1=1 then poke $50,"1" :endif         'CreatePacket1
     if pin2=1 then poke $50,"2" :endif         'CreatePacket2
     if pin3=1 then poke $50,"3" :endif         'CreatePacket3
Checksw:
    if pins=%00000000 then Main
Decroutine:
       if pin4=1 then poke $50,"5" :endif             'CreatePacket5
    if portc pin2=1 then poke $50,"6" :endif         'CreatePacket6
    if portc pin2=1 or pin4=1 then datalenght_chk
Focus:
        if pin4=1 then poke $50,"7" :endif         'CreatePacket7
        if portc pin2=1 then poke $50,"8" :endif     'CreatePacket8
 datalenght_chk:
       dataLength = 1
        GOTO Send
Emergency:
        dataLength = 1
        POKE $50,"0"
'        GOTO Send
Send:
CalculateCrc:
        crc = 0
        bytePtr = $50
          PEEK bytePtr,byteo
          bytePtr = bytePtr+1
          GOSUB CrcAdd
        NEXT
PowerUpTransmitter:
        HIGH POWER_ON_PIN
   HIGH POWER_UP_LED
SendPreamble:
   TOGGLE TX_LED
        NEXT
SendStartOfMessage:
SendDataLength:
SendData:
   TOGGLE TX_LED
   bytePtr = $50
          PEEK bytePtr,byteo
          bytePtr = bytePtr+1
        NEXT   '#############################
SendChecksum:
        SEROUT TX_PIN,TX_BAUD,(crc)
SendEndOfMessage:
SendPostamble:
   TOGGLE TX_LED
        NEXT
   GOTO Main
CrcAdd:
      FOR bit = 0 TO 7
       k = byteo ^ crc & 1
       k = POLYNOMIAL
      CrcAdd1:
       crc = crc / 2 ^ k
       byteo = byteo / 2
      NEXT
 RETURN
This is now fully operational code yet to be hardware tested though.
The receiver checks the code in $50 depending on what it is it then switches on the outputs. (this part of the project is still being developed) once I finish it I will post it in the forum.
BCJKiwi
I had changed the logic initially without the 'goto createpacket' but considered this fundamentally changed the logic.
I don't know what the possible mix of conditions on the pins might be or if there is a hierarchy of importance, but the new code is fundamentally different from the original as all the tests will occur regardless and all store to the same location thus overwriting each other. Previously the code branched from the tests to the action immediately a pin test was satisfied.
Is there a particular reason for not sending two bytes in the serouts where possible?
Wombat_In_Space
No reason, this is the fist one I have written for a picaxe to send a data string to turn on an output on another, normally all I use serout for is LCD's.
BCJKiwi
It is just that bytes can be saved and performance improved if you send more bytes in one session. e.g. these two changes;
'SendStartOfMessage:
 '  SEROUT TX_PIN,TX_BAUD,(SOM_BYTE)
        SEROUT TX_PIN,TX_BAUD,([B][I]SOM_BYTE[/I][/B],byteo,[B][I]dataLength[/I][/B])
'SendDataLength:
and
SendChecksum:
        SEROUT TX_PIN,TX_BAUD,(crc,[B][I]EOM_BYTE[/I][/B])
'SendEndOfMessage:
save 9 bytes and should reduce processing time.
Wombat_In_Space
Thank you again since the start of this tread you have taught me new ways to code and have found my 11 bytes I was over and gained me 14 so total of 25 bytes found. (Dancing smiley)
