Bill.b
This is a sample of code I used to adapt a Wii cassic controller for my latest robot.
I used the controller to set the speed and direction of the drives as well as controlling the video camera ( manual or auto pan and camera ON / OFF)
in this sample I have not seperated the buttons from bytes 4 and 5, the table supplied indicates the individual bits assocated with each button.
I will present the full program and schematic for the robot when I have completed testing.
Bill
' Program to read data form a Wii Classic Controller into a picaxe 28X2.
' Bill Brown Bill.b 29th July 2013
' I have tested the program with a 40X2 and it worked OK. The program does not work correctlly with M2 chips
' Some more work is required for M2s
' The Wii Receiver module required a 3.3volt supply.
' In my test unit i derived the 3.3v by connection two IN4001 diodes in series to the 5v supply giving approximatly 3.4v.
' 4k7 pullup resitors are unsed on the SCL and SDA - Connected to the +3.4v supply
' Data format for the 6 bytes of data from the Wii Classic Controller (WiiByte0 - 5)
'|Byte | Bit |
'| | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
'| 0 | RX<4:3> | LX<5:0> |
'| 1 | RX<2:1> | LY<5:0> |
'| 2 |RX<0> | LT<4:3> | RY<4:0> |
'| 3 | LT<2:0> | RY<4:0> |
'| 4 | BDR | BDD | BLT | B- | BH | B+ | BRT | 1 |
'| 5 | BZL | BB | BY | BA | BX | BZR | BDL | BDU |
'LX,LY are the left analogue stick, X and Y (0 - 63). RX and RY are the right analogue stick, X and Y (0 - 31).
'LT and RT are the left and right triggers (0 - 31). The left analogue stick has twice the precision of the other stick
' BD(L,R,U,D) are the D-Pad direction buttons. B(ZR,ZL,A,B,X,Y,+,H,-) are the discrete buttons.
'B(LT,RT) are the digital button click of the LT and RT. all Buttons are 0 when pressed.
#picaxe 28x2
setfreq m8
symbol WiiByte0 = b7 'Wii byte 0
symbol WiiByte1 = b8 'Wii byte 1
symbol WiiByte2 = b9 'Wii byte 2
symbol WiiByte3 = b10 'Wii byte 3
symbol WiiByte4 = b11 'Wii byte 4
symbol WiiByte5 = b12 'Wii byte 5
symbol WiiTemp0 = b13 'Wii Temperary storage byte
symbol WiiLeftX = b14 'Left stick X axis 0 - 63
symbol WiiLeftY = b15 'Left stick Y axis 0 - 63
symbol WiiRightX = b16 'Right stick X axis 0 - 31
symbol WiiRightY = b17 'Right stick Y axis 0 - 31
symbol WiiLeftT = b18 'Left trigger 0 - 31
symbol WiiRightT = b19 'Right trigger 0 - 31
i2cslave %010100100, i2cfast_16, i2cbyte 'I2C setup for Wii controller
hi2cout 0,($F0,$55) 'Wii Configuration bytes
pause 10
hi2cout 0,($FB,00) 'Wii Configuration bytes
pause 10
hi2cout 0, ($00) 'Wii Request data
'Main program start here
pause 70
hi2cin 0,(WiiByte0,WiiByte1,WiiByte2,WiiByte3,WiiByte4,WiiByte5) 'Data from Wii Controller
'The following section arranges the data from the Wii bytes 0 - 4 into seperate bytes for used in the program
pause 50
WiiLeftX = WiiByte0 & %00111111 'Left stick X = Bits 0 - 5 of wiibyte0
WiiLeftY = WiiByte1 & %00111111 'Left stick Y = Bits 0 - 5 of wiibyte1
WiiRightX = WiiByte2 & %00011111 'Right stick X = Bits 0 - 4 of wiibyte2
WiiRightY = WiiByte2 & %10000000 'Move bit 7 of wiibyte2 to Right stick Y
WiiRightY = WiiRightY >> 2 'shift right 2 places
WiiTemp0 = WiiByte1 & %11000000 'move bits 6 & 7 of wiibyte1 to temp
WiiRightY = WiiRightY OR WiiTemp0 'Combine temp and right stick Y
WiiRightY = WiiRightY >> 2 'Shift right 2 places
WiiTemp0 = WiiByte0 & %11000000 'move bits 6 & 7 of wiibyte0 to temp
WiiRightY = WiiRightY >> 3 'Shift right 3 places. Right stick Y byte completed
WiiRightT = WiiByte3 & %00011111 'move Right Tigger bits 0 - 5 form wiibyte 3 to wiiRightT
WiiLeftT = WiiByte3 & %11100000 'move left trigger bits 5 - 7 form wiibyte 3 to wiiLeftT
WiiLeftT = WiiLeftT >> 3 'shift right 3 positions.
WiiTemp0 = WiiByte2 & %01100000 'Move Left trigger bits 3 & 4 to temp
WiiLeftT = WiiLeftT OR WiiTemp0 ' combine wiiLeftT and Temp
WiiLeftT = WiiLeftT >> 2 'Shift right 2 positions to complete wiiLeftT byte.
'debug
Bill
